360 CAMERA SYSTEM RETROFIT W213
  • Thread starterplamen
plamen
has anyone done 360º CAMERA SYSTEM RETROFIT on W213 pre facelift.includes wiring 3 cameras(when you have only rear) are the cameras in the mirrors and the front camera different?
maybe that's all it takes
360-camera-system-retrofit-kit184653
Reactions:avecesveobugs
Have you tried to install 360 cameras for yourself? What did it take?
Reactions:kazazaeva.o
It will require coding and possibly new control units if 360 cameras came on a newer model than you have. In addition, you may need to run all the wires for the cameras, as they tend not to be included if the car wasn’t optioned with 360 view. This will require access to wiring diagrams.
should the schemas be in xentry?
you can work in offline/test mode and search around for the entries you need to modify. thats how I usually map out my changes and then trial and error them on the car live to see what works or does not.
Reactions:avecesveobugs and wolf38
All camera can be same. Code and learning via dts.
  • IlanISR
IlanISR
  • maciek2406
maciek2406
Z
  • ZiMMeN
krugger
