A238 USB Ports update
  • Thread starterProphetuk
Prophetuk
Hi,
Happy New year.
I have a 2017/2018 A238 Cabrio and was wondering if anyone has attempted to update the USB ports on the main front console. At the moment it has a USB - B looking to update to a USB-C and also install a 12v port like the 2020 facelift model and possibly add ports to the rear as the Grandkids always want to use the one in the arm rest any body got part numbers or PDF's?
Thanks in advance
You can exchange the USB Port with an USB-C if you just connect the DATA +- and also the Power Cables to the right pins. For supporting PD or some higher charging power than the normal 5 or 10 Watts, use a PD power source directly connected to 12V instead of the USB power cable of the USB-B Port.
I hope this helped. :)
Reactions:Prophetuk
