AdBlue Reset
  • Thread starterbohrg1
bohrg1
Can anyone tell me if XENTRY PassThru can be used to reset AdBlue?
  • Love
Reactions:rafhic
  • P
    Given by Peter5
Sometimes Xentry fails to reset AdBlue level/remaining range.
If you have Vediamo, you simply reset the SCR system in the CR60 unit. If the AdBlue level sensor is working and there are no associated error codes, it will calculate a new remaining range based on the AdBlue level.
In Xentry it is in the special processes section, Xentry requests online access, but in some cases you can click "Continue" and the launch restriction will be removed. In Xentry it is not always possible to do this, in this case you need to use DTS Monaco.
Reactions:bohrg1
I have Vediamo, can I do the same with AdBlue?
The display just says that after a few km the engine will not start anymore.
Thanks.
Find "warnscenario" in the engine control unit.
Am I correct in understanding that I need to do this in Vediamo or do you mean Xentry?
Could you please explain this to me in more detail?
I would be very grateful.
If it doesn't work in Xentry, you can do it in Vediamo. In Vediamo, connect to the engine block, then click on the binoculars (search) and enter "warnscenario" in the search line, then click on this function, the mileage limit is reset. I don't have free time to describe this in more detail.
Reactions:tsulovari, hasan741 and bohrg1
I don't know what model of ECU you have, but you can refer to this document.
  • Bosch_Resetierung_Warnszenario_Kurzanleitung_B5M0_V24_V33.pdf
Reactions:tsulovari, Ditcha, hasan741 and 10 others
I think I have the same problem with my GLE 350 Bluetec (W166).
My car was in for repair a few months ago and it turned out that the AdBlue lines had crystallized.
I cleared the whole system, deleted the error codes and they don't appear anymore.
However, the mileage limiter is always on.
Does anyone know if it can be unlocked with Xentry?
I would really appreciate it if you could help me.
Reactions:Peter5
Reactions:hasan741
Xentry does not always reset AdBlue, but you can also use AdBlue removal emulator, which prevents all AdBlue system errors and has good compatibility with almost all brands.
  • asigur
asigur
  • livedog
  • DTS Monaco
Lenow500
  • tecnomatic
PeteM123
