After flashing w204 module brake pressure error came
  • Thread starterpomsingh
pomsingh
Banned
I flashed esp module of w 204 and after flash brake pressure sensor error has come. When checked there is no pressure sensor in my car. my car is not equipped with sensor.
Hello, did you backup the coding before? Then you can play it back after flashing.
Yes I did but even after installing old one back its same issue.
What tool did you use to flash the esp?
The w204 Esp ECU is well known failure quote. In most cases there is a problem in the ic circuit.
Last year I repaired more then 20 units!
I used launch pad 5 online programming scanner.
Why did you flashed the ECU. Was there any reason, because of an other failure?
We recommend to flash with proper Falshtool and Stock flash
In my opinion, incorrect coding for your car.
Yes sure, to first flash with stock flash and than to finalize Scn coding.
Perform SCN coding.
  • noman223
Rade1978
  • Rade1978
Rade1978
Rade1978
