Airmatic Mercedes Suspension Retrofit to Standard Springs
  • Thread startermaba41
maba41
After repeated damage to the air suspension on my W211, I installed a regular coil spring suspension and was able to get rid of the "Low air, wait for level raise" message. Is it possible to reprogram the ECU to disable the air suspension module?
Start DAS -> Select your car -> CGW -> Control unit adaptations -> Read coding and change -> ALL codes -> Air suspension -> set "Not present" -> F3 -> F5 -> F3.
Instrument cluster -> Diagnosis to plant specifications -> Control unit adaptations (Variant coding) -> Variantencodierung Werkseinstellungen -> Airmatic -> set "nicht vorhanden" ->F3 -> F3 -> F2.
Hard reset in CGW and instrument cluster.
In order for the headlights to shine correctly, it is necessary to install an additional non-standard unit.
Reactions:jurek1980, 1spat and maba41
