Audi Q7 Sunroof Problem
  • Thread startermelih22
melih22
I have a problem with the sunroof. I get this message from VCDS:
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Dataset Number: 4M0909469E 0013
Coding: 608000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: 73B3DFD17B36D642529-8026
3 Faults Found
0264 - Sunroof
B1543 54 - Missing Calibration / Basic Setting
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 210228 km
Date: 2024.08.10
Time: 1528
Sunroof-Position: 0 %
Sunroof-Direction of movement: Not moving
Sunroof-Norming: not normed
Sunroof-Position: Tilt out posi.
Sunroof-Excessive temperature protection: not active
Sunroof-Reversing: not active
Sunroof-Adaption depth: 100 %
0274 - Roof Shade
B1544 54 - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 210228 km
Date: 2024.08.10
Time: 1528
Roof shade-Position: 0 %
Roof shade-Direction of movement: Not moving
Roof shade-Norming: not normed
Roof shade-Excessive temperature protection: not active
Roof shade-Reversing: not active
Roof shade-Adaption depth: 100 %
0325 - No Vehicle Type Coded
B1694 00 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 210228 km
Date: 2024.08.10
Time: 1528
I'm sure the coding is wrong but I've never changed anything in this area. I googled and found the same issues but with custom cars, how do I find the correct code for my car or the previous code?
Change the coding to 608000053602. After coding, perform basic settings.
  • Ramikadze
Ramikadze
  • misterp
misterp
  • XENTRY Diagnostics
9K
