ucmb
- Solutions
- 1
- 21
Attached to this message you will find an external link to download an outdated version of the official BMW Technical Information System (TIS) in DVD format, released back in late 2007 for repair and maintenance of BMW and MINI vehicles up to 2008. Currently the Technical Information System (TIS) is available in ISTA, but it may still be interesting to look at this version.
How to install?
Unfortunately, this software is too old to run on Windows 10 or Windows 11. I recommend installing it on a Windows XP (32/64-bit) virtual machine. I heard that it can also run on Windows 7 in XP mode.
In any case, to install it you need:
How to install?
- Mount the ISO file.
- Run the file "BMW_CD\Win95\BMW\TIS\Setup.exe". It will install and add to your desktop a program called "Sysadm".
- Run the file "BMW_CD\Win95\ODBC_XP\ORACLECLI.MSI". I believe it installs Oracle Client to communicate with the database.
- Open "Sysadm" on your desktop, click the TIS tab and select "Install". Note that you need to select the hard drive install so you don't have to mount the ISO again.
- Once completed, you will be able to open the TIS software from your desktop.
