Carly OBD2 Car Scanner v48.95 Unlocked
  •  Android Download
  • Thread starterpapaosman
papaosman
papaosman
Note. You will not be able to login via Google (since the application has been modified). You can use your Facebook login or regular login + email password.
- Useless files deleted
- All features unlocked
- Debug info removed
- Graphics optimized
- Languages: All
Carly Diagnostics
The health of your car is in your hands. Fault code data combined with additional information from up to 80 ECUs gives you a complete overview of your vehicle's health and prevents future issues.
Carly Smart Mechanic
Improve your repair skills. Advice from experienced mechanics will help you understand the severity of the problem and how to fix it.
Carly Coding
Be in control and unlock hidden features or change settings to customize your car specifically to your needs. Coding your car is user-friendly, intuitive and safe.
Carly Engine Live Data
Always be up to date. Access your engine data in real time and use our suggested parameter selection to obtain reference values to narrow down the causes of issues.
Carly Maintenance
Stay on top of service needs. The Carly Maintenance feature helps you to keep track of your service intervals and reset your service light with your smartphone.
  • Carly OBD2 car scanner v48.95.zip
Reactions:paashaas, vamp2, 94ttsupra and 7 others
Any suggestions like ELM327 for this application?
Not sure, but I think only the Carly OBD adapter works with this App.
By the way, I have a Carly adapter and have not tried this App with another OBD scanner.
Has anyone tried this with an ELM327 yet?
Hi, is it compatible with E89?
Compatibility of all supported functions (Diagnostics, Coding, etc.):
1-Series (E81, E82, E87, E88)
3-Series (E90, E91, E92, E93)
5-Series (E60, E61, E63, E64)
7-Series (E65, E66)
X1, X3, X5 and X6 (E84, E70, E71, E72), Z4 (E89)
Mini (R56 or newer)
F-Models
Reactions:Sebdemontpel
Reactions:Doughy2002
  • misterp
JohnLi
  • misterp
misterp
kamelmdk
  • kamelmdk
9K
Bonnie0
