Carplay W205 HU5ES2
  • Thread starterbogdandpr
bogdandpr
Hello, is anyone kind enough to help with correct smrf to activate Carplay for this W205? thanks a lot
VIN: WDD2050451F645201
HW: 2059011717
SW: 2059025921
SW: 2059021618
SW: 2059021219
Search in REMOTE UI APPLICATION WRITE
Over there
REMOTE UI APPLICATION on
CarPlay via USB on
Automotive link via USB on
Reactions:marecek1004
Over there
CarPlay via USB on
Unfortunately coding is not enough, it changes back to original after reset. AFAIK it needs update/downgrade when this happens, I am not really experienced with CarPlay, but its a close friend and I am trying to help him.
You can not active CarPlay with this SW. Downgrade SW and activate CarPlay.
It can be activated on all sw having sa154, if you have 18.31 it is also possible to activate it without having to downgrade the software.
Flash this 2059020919, then make coding.
Reactions:marecek1004 and bogdandpr
There is no need to update to any specific sw, it is possible to activate it on any sw, without having to flash anything at all.
Reactions:bogdandpr
Finally, do you find the solution? I have the same hardware and software, and I have the same problem. It doesn't save the coding.
Unfortunately not.
  • bogdandpr
BIBSHIGE
  • merccc
atomantmk
  • bogdandpr
merccars
