Chip tuning on w203 c180K
  • Thread startertomka37
tomka37
Chip tuning on w203 c180 kompressor worth doing?
Yes, it helps a lot. The best way to do it is finding a c230k file and copy everything. It has a lot less restrictions than the c180 and c200k. I had a pain in the ass trying to tune mine a few yeara ago
Thanks for your answer! where you can find files from c230k?
do you have kess clone? if you do you can read the file and I strongly recommend you to do a full rezd back up. so if you mess something up you just flash it in boot mode and start again
see attachments, thats a gift for you. I paid someone to make me that mappack because every tuner I found just make stages on those cars because they dont have proper mappacks. there is a stock c230k file so you can compare your c180k file with it and change the values so you use the same checksum of your ecu so you don brick it. then when you write it to your car test it and later read it again and use that file as a base for future tunes and send that mappack to your tuner so it can make a custom tune and not just a stage 1 or 2
I used that mappack when i installed a smaller pulley on my c180. If you install the pulley without a tune the car gets super lean and starts to knock
  • c230kandmappack.rar
Reactions:tomka37
Hi mate,
Chip tuning of your W203 C180 Kompressor, chip tuning can potentially offer several benefits:
Increased Power and Torque: Chip tuning can optimise the engine's fuel and ignition timing, as well as boost pressure (in the case of a supercharged engine like the Kompressor), to extract more power and torque from the engine. This can result in improved acceleration and overall performance.
Enhanced Fuel Efficiency: By optimising the engine's parameters, chip tuning can sometimes improve fuel efficiency, particularly if the engine is running more efficiently and effectively utilising fuel.
Customisation: Chip tuning can be customised to suit your specific preferences and driving style. Whether you prioritise performance, fuel efficiency, or a balance of both, a skilled tuner can tailor the remap to meet your needs.
Better Throttle Response, Optimising the engine's parameters can often result in improved throttle response, making the car feel more responsive and dynamic to drive.
but there will be some downsides,
Warranty Concerns, Modifying the engine's software can void or impact the manufacturer's warranty.
Reliability There's always a risk that aggressive tuning could lead to premature wear or mechanical issues. It's crucial to choose a reputable tuner and ensure that the modifications are within safe limits for your engine.
Also think about Legal Considerations
  • handygraphy
handygraphy
  • garybuscc
Christi325
  • tomka37
tomka37
