CLA 117 Active Bonnet Fix by Bypassing Bonnet Actuators
  •  Manual
  • Thread starterlarryphonetech
larryphonetech
This is a cheap fix for bonnet actuators on pedestrian system!
Bypass the actuators with 1.6 Ohm resistor and get rid of active bonnet malfunction error!
Check video for full details!
  • y2mate.is - Bypass Mercedes Benz Active Hood Malfunction-nW84UJ_ozFo-144pp-1697070702.mp4
    11.1 MB
Reactions:localmode, Dashb22 and Real
Research is a good way to figure out the problem, but bypassing the security functions in a customer's car is irresponsible!
You should use a larger resistor since the minimum required resistance is 1.6 Ohm. Perhaps use 2.2 Ohm.
Hi, no resistor is needed. Coding using Vediamo only.
Change the coding to ORC166 via Vediamo.
Reactions:thingsarehere, BUGBEAR and amgrace
Disable PPS ORC166 using DTS Monaco.
  • larryphonetech
edward7722
  • Marketplace
17K
  • XENTRY Diagnostics
9K
