Component protection
  • Thread starterhafsa
hafsa
Junior member
Hello.
Plz usually when change instrument for GOLF 6 or caddy equiped with instrument nec 32 or 64 we get issue with radio component protection (cp).
Read data from old with any tool avdi or vvdi write data to new one car start but radio not work.
For radio which work with pin no problem but the radio in cp is problem.
I heard that data in dash (cp radio need to transfer to new one).
Any tool able to transfer this data?
You do not need to transfer the data just yet there are other options available.
1. Enter vehicle details in ODIS
1710789864308
2. Run full diagnostics
1710789961986
3. You should see the a few Test plans generated. Switch back to the 'Control modules' tab
1710789996217
4. You should see the 'Information Electronics' (005F) right click it
1710790070628
5. Right click and select Guided Functions
1710790206938
1710790138368
6. Click Run and let the tool complete its programming. The CP should be resolved after the run is complete.
Reactions:daniel.bulai and cloud9atom
Thank you very much for this guide. But will it need online to access?
It should not require online access. It would be better to turn off the internet while doing offline programming such as this. The only thing you will need is the laptop, ODIS tool, and the connector make sure your laptop does not turn off during any programming to avoid issues in the process.
Not found protection function.
Only:
Actuator diag
Adapt
Basic setting
Erase event
Identify
Read measured values
Replace
You cannot remove CP with ODIS offline, only with GeKo account online.
Even online failed to solve the problem.
What is the fault you are seeing when you try to remove CP with ODIS online, can you post a picture?
Normaly the gateway gets wet and you have such problems.
  • GanPower
GanPower
ExpatMat
  • ExpatMat
ExpatMat
ExpatMat
  • satmonster321
waxxx
