DAS Add ECU CBFs to a Model R170
  • Thread starternemiro
nemiro
I have an R170-based car (Chrysler Crossfire) that I have swapped many components in. It now has an M113K V8, and a 722.9 transmission, EIS, ZGW, and more. None of that was available on any R170.
The issue is with DAS. Right now, I have to hop between models to get into each of the ECUs in DAS. The engine controller (ME2.8.1) was easy, because some R170's did come with that controller (SLK32). I want to be able to see these under the R170 Control Units menus.
I was able to add the VGSNAG2 into the definition file attached. However, as I tried to add the others, which are from W211 (EZS, ZGW, ESPMK25), they will not appear in the menus. Is there another set of definition files somewhere that determine what will and will not appear in the menus?
  • 170_b_03.rar
Reactions:taha0000, sidney and omsitbin
I tried the same thing recently, but for Xentry.
I need access to comand 5.1, display and control unit for w204/x204 models (things were never installed in this models).
I'm able to see all of them in short test, but it's failed to me read errors/live data/etc.
I'll continue my reserach and report you back in case this will works well - may be my experience will help you with R170.
Reactions:nemiro
Absolutely! Can you tell me what files you are modifying in Xentry?
.\Xentry\Kontexte\CaesarProjekte\ PKW_204.xml
.\Xentry\Kontexte\CaesarProjekte\conf\ PKW_204.txt
.\Xentry\Kontexte\CaesarProjekte\conf\ PKW_204_Topologie.csv
.\Xentry\Kontexte\CaesarProjekte\conf\ SeriellNumber.txt
.\Xentry\Kontexte\CaesarProjekte\ping\ PKW_204.csv
.\Xentry\Kontexte\CaesarProjekte\ping\pingplusplus\ PKW_204.xml
.\Xentry\Kontexte\CaesarProjekte\Sim\ PKW_204.xml
Thank you, Sidney. I am working again on the DAS files, and will post up what I find.
  • avarec
avarec
