DAS reprogram the total kms - in 203 retrofit ICM
  • Thread starterBruto
Bruto
Bruto
As if possible, reprogram the total kms - - - - - - in a 203 retrofit ICM via DAS or Vediamo, please help :sneaky:
continuing the research...
and speaking alone...
The Vediamo command to write to the CCID is 31 04 00 00 00 00 used? (RT_ODO_vorsetzen_Starten)
Yes it is also possible :sneaky:
Yes? Can you post more information? My friend's W203 has sport gauges with varying mileage, but I need to add a few more kilometers.
I can only do it as in the video, copy the km that are registered in the EZS into ICM.
After doing A, do 11 01 (Hard Reset) and then 3B 02 (FN_Write_EZS_Key_ID_To_EEP).
diag111
  • norki21
Bari87
