julmari
- 20
I spent many hours trying to cope with the situation. Interfaces did not work in DTS 8.16 with a new installation of Xentry 2023.9!
The problem is that support for 32-bit PDUs has been removed from Xentry, and the native DTS Monaco drivers do not work with the Bosch MTS6532 MUX.
I fixed the problem as follows:
For Interface CBF
I copied the PDU directory "C:\Program Files (x86)\Mercedes-Benz\Xentry\bin\PDU" from Xentry 2021.9 to the same directory in the new Xentry installation.
Then I changed slave.ini in "C:\Program Files (x86)\Softing\Diagnostic Tool Set 8\8.16\Interfaces\DCDI30".
RootPath="C:\Program Files (x86)\Mercedes-Benz\Xentry\bin\PDU\pdu_api_root_bosch.xml"
DeviceOptions="
Then I made the settings as in the picture (eCOM_CBF).
For Interface SMR
I changed in System Settings / Directories "D-PDU API root description file" to "C:\Program Files (x86)\Mercedes-Benz\Xentry\bin\PDU\pdu_api_root_passthru.xml" and made the settings as in the picture. MTS6532 works as J2534 device, MTS6532 API does not seem to work.
Please remember to use "nofilter" when selecting connection on SMR.
This maybe will work C6 clones too, please report if you have success.
For Interface CBF
DeviceOptions="
For Interface SMR
