GLS450 Bulb to LED on Daytime Running Lights
  • Thread starterDiagnos11
Diagnos11
Hello together,
I need help on my GLS450 W166 to change Bulb to LED on Daytime Running Lights
I would like to know what i need to change on SAM (Vediamo: CBCBOLERO.CBF) or anywhere other?!
In the car is no Ecus for Front Lamps!
The problem is, the Bulb need 55Watt and LED need only 10Watt, and if the SAM didnt give the 55Watt, then the LED start to blinking.
i would like to know what need to change for make workable LED without blinking!
Thanks in advance
Regards
Do you want to replace your fog light
for daytime running light?
Power for the fog lights and daytime running lights is taken from different contacts of the SAM ECU. Coding will also be required.
Reactions:samo
Thanks for the diagram, but i need to change on my Day light from Bulb 55watt lamp to LED 10watt lamp, and if i do it, the lamp light 2 min and then starting to blink, because the ECU think that lamp are dead and try to reanbling, so like that i need to know where i need to change in vediamo the settings for voltage of lamp for make the LED working without blink, that ECU see ok lamp are not DEAD with 10watt
Z
EduardNN
  • Delon
Delon
cablondon
