crypt0ninja
- 88
The cheap GODIAG J2534 (GD101) Passthru interface can be used with CLIP (I have no idea how good/bad it works with CLIP, but you must make sure firmware is up-to-date as CLIP compatibility was only introduced in the most recent firmware versions).
For CLIP to recognize this interface as a sensor you need to create a new registry entry for the interface and change some values.
I exported the modified registry entry so if you own this interface all you need to do is run and import it and it should work as a sensor in CLIP.
