Handed3219
- 6
Lane Assist is an safety feature which works fine on a highway but on other roads it's hit & mis. Therefore I want to change mode from reset to last mode.
When connecting with Xentry this option is available within the multifunction camera MFK ECU which is using the MMPC213.smr-d file.
When connection to ECU EZS167 for temp disabling the firewall security level 3B I still can't read out the MMPC213 ECU and results in an timeout.
STAT: The D-PDU API call has failed; DYN: PDU_ERR_EVT_RX_TIMEOUT: Indicates that an expected response was not received within the defined timing window (307) ErrorCode: eRT_PDU_API_CALL_FAILED ( 0x0000D090 )
To be sure I've checked the MMPC213.smr-d version and build, and it's the same as Xentry is using build 02.03.62 date 2021-08-24T0819.
I've followed the correct procedure with first temp disable the firewall and then connection to this ECU but somehow I can't connect. Can someone point me to the right direction? Much appreciated.
