HHT SDconnect or C4 OTVDM for XENTRY Diagnostics
  •  Extras Download
Moderator
Staff member
Developer
HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.01
HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.02 HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.03 HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.04 HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.05
Several users asked to recompile the HHT with OTVDM.
I looked at the OTVDM sources and I have a lot of "IFs" and "BUTs", at a minimum you will not be able to run applications under a virtual machine.
This build of HHT is compiled to work with XDOS x64 (XENTRY Diagnostics OpenShell) using OTVDM.
The HHT itself is identical to the one in the previous thread.
HHT gets its launch parameters from DAS/XENTRY, so I don't recommend launching it directly, but only from XENTRY or DAS Standalone.
It works with SDconnect/C4 only.
If you need HHT for professional work, use the commercial version, which has nothing in common with this build.
If you have/had problems with the HHT NTVDMx64 version, before installing this version, first use the "NTVDM Uninstaller" program, which can be found in the attachments.
XENTRY Diagnostics OpenShell version: v03.2020 and above
OS: MS Windows 10 and above
Installed size: 171.84 MB
  • HHTWin.SDconnect.OTVDM.For.XENTRY.Diagnostics_autogmt.com.rar
  • NTVDM.Uninstaller_autogmt.com.rar
Reactions:merccars, kamelmdk, karakan08 and 27 others
  • XENTRY Diagnostics
