How to Deflate Airmatic Suspension Using XENTRY?
  • Thread starterbenidenesene67
benidenesene67
I recently purchased a MB E300D 2014.
I need to replace the Airmatic suspension. Can anyone give me step by step instructions on how to deflate and reinstall the new suspension using Xentry?
I think I need to deflate it using Xentry first.
Reactions:edith
  • B
    Given by bigchevy66
You don't actually need to use the Xentry to deflate the suspension, and we never do it at the dealership. Simply unscrew the air line from whatever component you are replacing and let the air escape.
Yes, you should use Xentry to inflate air struts/bags after they have deflated. As a general rule, it is not recommended to leave the vehicle with a completely deflated air strut/bag as you risk damaging it. I put the car on a lift and gradually fill the air struts using Xentry/Airmatic/Actuations, then use whatever filling procedure you require. Once there is some pressure in the air struts and the car is not completely lowered, you can lower the lift and allow the car to rise to the desired ride height.
It's not that big of a deal.
A little help. This might be useful.
  • airmatic procedure.pdf
Reactions:benidenesene67
Reactions:edith and benidenesene67
  • Ihl82
Djole
  • BenzProber
ucmb
ucmb
  • babijoe
babijoe
