HU5ES2 Shipment Mode Help
  • Thread starterFaultier
Faultier
After finally getting everything working with my head unit, I'm now sitting on the real problem. I wanted to unlock Android Auto and now I have a Panasonic head unit installed. Everything works except navigation via SD card. I found out how to unblock everything on another forum. But every time I unlock the functions they reset. Then I read that I need to put the head unit into shipment mode, but I just can't get into shipment mode. I don't have any buttons on my HU, and all attempts to enter engineering mode were also unsuccessful. I don't know what I'm doing wrong.
Faultier from what I've read, if you can't enter engineering mode (by pressing left in the car menu) like I can on NTG 5.1, it needs to be unlocked by coding.
I haven't been able to try this as my adapter isn't here yet and I'm not sure if it's exactly the same on 5.2.
In my other head unit I had engineering mode in variant coding in DTS Monaco, but the Panasonic head unit does not have such option.
Reactions:Merc
Is it really enough to have one line in the head unit to enable the engineering menu by coding?
Reactions:Faultier
You don't need to enable shipment mode to activate CarPlay and Android Auto.
Reactions:mckansis and Benzfahrer
Can you explain how to activate CarPlay without downgrading software?
I tried several times to write the 05.05 string using the UDS command, but it didn't work.
I just have to flash it every time.
Reactions:mckansis
I have also tried several times and as far as I know, you need to do coding and backup. Then you need to reset the settings and play in the backup.
Reactions:Benzfahrer
You don't need to do any of this, the feature can be activated by coding.
Ok, I use DTS 9 and Openport, but after setting the coding to 0504...04...19...04 and resetting it still remains off, only the manual I see in the instructions.
So I connect to "HU5ES2" then go to change coding and it shows me the existing code which is what it should be but in the overview all 3 settings still show as "off". I know I'm not the only one who tried and eventually gave up. I assumed that maybe DTS 9 couldn't do this.
It doesn't work for me. Then there must be some trick or routine. Coding alone won't help. I tried many variations, but nothing helped.
michettiracing2
  • ClkCabrioDriver
chaosb93
  • Kosmix
Kosmix
