HU6 Display Went Blank After Coding W177
  • Thread starteriSoda
iSoda
Yesterday I connected Launch to the car and went into the HU6 unit to do some variant coding. I did not change any parameters, but when I pressed the "write coding" button, the display of the head unit went out and does not turn on anymore. Errors appeared.
Launch set default coding to HU6 :)
Now you need SCN online or try to manually code with another device, not Launch.
Can you tell me if Openport can do this?
What type of Openport do you mean? If it's Tactrix, it didn't help me, lots of connection issues.
Now I use C4 multiplexer to code all modules on current car.
Reactions:rimedre
Managed to code almost all functions, the display turned on. The rear camera and dynamic selection modes do not work.
Now everything works. I have a file with the correct coding for my car. If someone needs it, I can share it.
Reactions:P7uggy
I would be interested in help in this area as I think I have a similar problem.
bigchevy66
  • newbymb
tecnomatic
michettiracing2
