Jaguar XF Gost
  • Thread startermaba41
maba41
The screen display display partial info, ENGINE NO START, with activity in ECU control and all kind codes. Very common problem for this models, NETWORK FIBER RING COMMUNICATION INTERRUPTED! Damage was created by water moisture and corrosion at BlueTooth module located under driver chair.
Repair steps:
1-move driver chair all way back, disconnect wires and remove screws from frame
2-with chair out, lift carpet cover box of BT module and disconnect wire plugs and fiber optic ring connectors
3-remove 2x modules, open metal box and inspect the boards for corrosion and rust
4-if board damage, REMOVE BT FROM NETWORK RING AND RETROFIT THE CONNECTION to bypass damage module by transfer male /female fiber plugs
5-turn ON ignition and check if DATA RING IS RESTORE, The display will work again normal and CAR WILL START, Clear all stored codes from system
6- if needed you can install a good used BT module in line, if not a soft code will set for BT disconnected or not present.
Maybe a guru programmer will show how BT will be REMOVE FROM Configuration of Network ring. Good Luck!
  • maba41
maba41
  • fafaza
dicsun
RazeR1
  • RazeR1
scanman785
scanman785
