Mercedes-Benz EPC v11.2018
  •  Activation Download
Moderator
Staff member
Developer
Mercedes-Benz.EPC.v11.2018
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.01 Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.02 Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.03
EPC is an electronic spare parts catalog for official Mercedes-Benz dealers, which has become online.
EPC v08.2018 is the last offline version of this catalog.
This activation will never be lost as this is a very common problem, the ID is always the same and does not depend on the network controller.
You do not need to use anything extra.
Developer server logs, market report requests and performance data collection for statistic pages that no one needs and that grows exponentially have been deactivated.
Local server remapped to port 5191 to avoid compatibility issues with XDOS/XPT, data card works of course.
The EWA Admin Tool is configured to run as administrator, the EWA interface is configured to automatically launch from MS Internet Explorer and patched with new server port.
You can install the activation package at the beginning of the EPC setup or if you have it installed.
The first step is to install EWAnet from the EPC_1118_1of1_b1.iso file (ewa\setup.exe), which must always be run with administrator rights.
The program must be installed to it's DEFAUILT folder (C:\Program Files (x86)\EWA) always, only then you can start activation program.
EWAnet must always be installed to the DEFAULT folder (C:\Program Files (x86)\EWA) before you can run the activation program.
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.04
You can optionally disable one of these services:
  • EWA net DB EPC
  • EWA net DB WIS (Recommended if WIS/ASRA Standalone is or will be installed)
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.05
EWAnet requires Oracle Java SE to be installed.
If Java SE has not been installed before, the program will prompt you to choose whether you want to install and professionally configure Oracle Java SE 8 Update 162 from the Mercedes-Benz EPC v11.2018 package.
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.06
But if Java SE was already installed in the system, then the option will be blocked.
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.07
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.08
You need to assign permissions to the Administrator group (As workshop access authorization) and then start EPC/WIS installation from the Start menu > EWA > EWA Admin tool.
The default login is admin, the default password is admin.
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.09
You can create the WIS/EPC shortcut from Java Cache Viewer for better convenience.
Link with activation updated to new version dated 21.10.2023
OS: MS Windows 7 and above
Installed size: 30.55 GB
  • Mercedes-Benz.EPC.v11.2018.rar
  • Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.rar
  • Love
Reactions:thxg, zenz, moufassa and 97 others
I just bought a V-Class, 447, and this should come in handy.
Reactions:pasindu144, Ruzgear, abc1986 and 5 others
Are there any EPC updates adding electric vehicles? Specifically the EQC?
Reactions:pasindu144, Ruzgear, abc1986 and 2 others
Strange question.
There will be no updates for offline versions such as EPC and WIS.
If someone gives me an account for Starfinder, I will grab it completely and professionally and make a new version for everyone.
Reactions:bogdandpr, pasindu144, Ruzgear and 5 others
Thank you R00TR0w for the clear explanation.
I just bought my first Mercedes (W177) and I need to fix a couple of things.
I have this question. Since I'm mainly interested in servicing and repairing the W203/S203, is there an EPC exclusively for this model? Or do I need to get the whole EPC 2018.11?
Reactions:Ruzgear, AllordEmad and mercedesowiec42
Install only the full EPC.
Reactions:Ruzgear, abc1986 and AllordEmad
After the October updates, Windows Internet Explorer 11 is no longer supported and is being redirected to Microsoft Edge.
The distribution has been updated to avoid this problem on all systems, regardless of update.
The admin interface opens again in IE.
Mercedes-Benz.EPC.v11.2018.Activation_autogmt.com.rar link updated 21.10.2023
Reactions:abc1986, AllordEmad, c250 and 5 others
I have the following problem. When I want to run the activation, nothing happens. I click on activation file, but it doesn’t start. What am I doing wrong? I installed the EWA tool from ISO. My computer is not connected to the Internet. I installed XPT version 03.2023 and activated it with the Advanced Key.
Can anyone help me?
Renaming the original file name causes the launch to be blocked. This applies to all my published files.
Otherwise, only an antivirus or file modification/damage can block the launch and nothing else.
There is another crazy modification to the operating system that blocks encrypted files, but nothing more, as I wrote above.
Further condemnation is absolutely pointless. I described everything more than clearly.
PS. All the solutions I have published have been used without problems in my commercial activations since 2016 from XP to W11.
Reactions:waxxx, nikolas, R-Dambrowski and 1 other person
7K
