cablondon
- 29
This instruction shows how to use the DTS Monaco to enable the remaining fuel function on a Mercedes-Benz.
ECU:IC_204
Work with IC_204.cbf with release DATE: 15.12.2016 take a look with an editor (for example Notepad) into the CBF file. If you CBF file is older than it could be that you will not have the coding function.
This coding if not done by regular variant coding!!! It is different!
Steps:
1.Connect to ECU IC_204
2.Open tree download
Choose Entwicklungscodierung
Change Tankinhaltsanzeige im resierechner fromaus to ein
Click the check
3.Do a hard reset
ECU:IC_204
Steps:
Click the check
3.Do a hard reset
