Mercedes intake tumble flaps
  • Thread startermaba41
maba41
Mercedes intake tumble flaps stick, error p2006, very common to V6 3L ENGINE, Plastic actuator rod (poor design) get damage by carbon deposits in gallery and result to 8 hour labor to remove full intake and install after market metal rods. Is any way to disable/ edit this solenoids command signal and eliminate this future from ECU configuration without set any codes? Any help from smart guru programmers?
Yes it is possible, read flash and post.
Reactions:maba41
Yes it is possible with the right Tools. I have make the same on may cls 219. The work was a mess :)
Reactions:maba41
