Mitsubishi MUT3 with J2534
  • Thread starterjurek1980
jurek1980
What is the best J2534 interface to use for Mitsubishi with MUT3? I have an Openport Tactrix. It seems to only work with some kind of paid bridge driver. Since I will most likely only scan one Mitsubishi car, I don't want to buy some special interface just for Mitsubishi.
Will Scanmatik work, for example? Or maybe all devices need to use a bridge driver? If so, why does MUT3 have information about supporting Passthru J2534?
I have a Delphi eCOM, it used to work on this computer but now none of the firmware/software versions are recognized.
Reactions:jeffesin
  • D
    Given by dnwalker
I use MUT3 SE with SM2Pro with additional driver. I can get into most control units, but unfortunately not all. The engine control unit works without problems, but I only need it for diagnostics.
Mitsubishi J2534 interface does not support only MUT SE, need to replace the original Passthru VCI DLL. For Outlander G4, as I heard the dealer said you need online.
Reactions:jeffesin
MUT3 SE is only enough for testing. I don't need to update ECU etc.
So which VCI is preferable? Can it be made to work without paid bridge drivers?
Why don't I want to pay? Because most likely in half a year I will forget about the installed software and delete it. So I will have to buy it again.
In my shop I use Scanmatik 2 PRO original from Russia.
The software was installed in 2023 by one person. I am from Vietnam.
Reactions:jeffesin and jurek1980
You need RNM VCI, it works well.
Reactions:jeffesin
You need the MUT3 Passthru driver, otherwise you won't be able to use it directly with the J2534 tool.
Reactions:jurek1980
The best options for MUT are Scanmatik or Openport, but as mentioned, they require a paid third-party driver to work.
Reactions:Kamelionnn
CarDAQ+3 is very stable for many OEM programs.
A more interesting and affordable J2534 adapter is the original Scanmatik 2 PRO.
  • 39fb29dndf
123ger123
  • nemiro
nemiro
