Need help, Parkman 213 CLA C118
  • Thread starterSnkfear
Snkfear
Hello everyone! I'm having some trouble trying to activate some features on my CLA C118 pre facelift manufactured in 2023.
When I try to connect to Parkman ECU I get an error saying "MaxLenght violation (PDU is too long), required bytes 448, available 920."
1000056375
I've replaced some outdated smr-d files copying new ones from xentry install but when I try to replace the parkman one, DTS Monaco detects it as corrupted.
Can someone help me?
Thx in advance!
Reactions:mic4130 and Turonet
Hi, ur smr-d files to parkman its still to old because it doesn't show u variant of module, use a smr-d from Xentry.
Also u can try this one.
  • PARKMAN213.rar
Reactions:localmode, gadalayn, manu and 6 others
Thank you very much for the attachment, I'll give it a try later.
I already tried to change the smr-d file copying it from Xentry install, but when I placed it on the project DTS Monaco refused to open it saying that the parkman smr-d file was corrupted... but with the one you attached the project opens without issue! :D
Reactions:gadalayn and currumblera
Update:
With the SMR-D wojciech300 posted I've been able to connect to my parkman ECU and perform some coding.
At first I got an error saying that coding service was not supported in active session but after closing again DTS Monaco and unplug and replug the odb adapter it worked like a charm!
Reactions:Turonet
How did you manage to connect to PARKMAN213 and read codings using DTS Monaco? I have tried all the PARKMAN213.smr-d files I could find. Both old and new versions. And every time I connect to the device, when I try to read the coding, I get the message: "Error. Negative response received (26)". It seems I need to give extra access somewhere. I used DTS Monaco 8.16. Can you describe the entire sequence of actions starting from launching the DTS program?
Either it requires unlocking the firewall or if it is a W213 MOPF you will not be able to code PARKMAN without an enhanced certificate.
The car is GLB 250 4MATIC 2021. Where exactly do I need to unlock the firewall? In EZS167 I gave all access levels. After that I can do coding in CPC_NG, HVAC177, IC177, HU6, but I can't even read the coding from PARKMAN213.
I have uploaded some SMR-D files from the link below.
One of them is from 2023, which may solve your problem with old SMR-D files.
Hope it works.
  • PARKMAN213.01.rar
Reactions:ja231, Turonet, gadalayn and 2 others
  • Delon
Delon
