NTG5 Video in Motion
  • Thread startererenkilic
erenkilic
My car is 2016 w176 A-Class. I searched forum but I couldn't find anything. Is this possible in my car (video in motion)?
Reactions:CipNdjm
I'm not sure about a 2016, however, in my 2019+ Sprinter van, I can activate VIM by changing the following three settings using DTS in the "Parkman213" ECU (you'll likely have a different ECU):
Under "Functional Settings Write" change:
- SVS: Views Speed Limit Activation > FF (this deactivates speed limitation - you can also set it to something else. Same for the ones below).
- SVS: Views Speed Limit Deactivation (High/Entry) > FF
- SVS: Views Speed Limit Deactivation Frwd (Entry) > FF
Reactions:erenkilic
Hi, yes I think this is possible using either Vediamo or DTS you have to read in the forum posts, our friend dizel008 found a way to do it, I tried it and it works.
the place on the forum is:
Reactions:nikolas, jurek1980, mic4130 and 1 other person
  • nabillaabi
moufassa
moufassa
  • burspoke
burspoke
  • nikolas
nikolas
