misterp
- 8
OBD Mary Car Scanner for ELM 1.236
OBD Mary is an automotive diagnostic scanner, instrument cluster and trip computer with a number of interesting features.
Diagnostics
You can read and clear fault codes from OBD2 compliant control units. You can view trouble code descriptions and search the Internet with one click. Freeze frame data can be read if a fault code is activated. You can read current parameters such as speed, RPM, MAF, coolant temperature.
Dashboard
Use our OBD2 app as a dashboard. Create your own dashboard. You can customize almost all the parameters of the dashboard (size, color, position of bars, arrows, texts, labels, background, etc.) Resize and move the gauge in the edit mode to the desired location, simply using your fingers. Enjoy your style!
Trip computer
Track your trips with our OBD Mary app and ELM327 adapter. Keep the adapter connected to your car at all times and the app will connect to your car and record your trip data.
Diagnostics
Dashboard
Trip computer
- Trip time
- Fuel consumption
- Fuel cost
- Average speed
- Maximum speed, etc.
