smokiness
Donator
Has anyone successfully managed to disable the Start/Stop function in the CRR1.CBF file for the OM 607.951 engine? I use VCX SE with DTS Monaco/Vediamo.
What I tried:
Based on my research, the closest match for my CBF file is (CRD3.CBF).
Then I realized that my car had been remapped in the past and wondered if that could be the cause. If this is the case, then as far as I understand, the ECU will not be able to establish a successful connection initially.
I would appreciate if anyone has any ideas on how to achieve this. Thanks!
What I tried:
- The connection to the ECU is established without problems. However, when trying to perform diagnostic variant coding in DTS Monaco, no values appear and the screen is completely blank.
- Then I looked at the security levels but the only one visible was "Security Access Level 5". I initiated a connection and the logs said "Connection Established".
- Then I did the same with Vediamo 04.02.02, but unfortunately I had no luck.
