OP-COM v1.39 for Opel
  •  Tools Download
  • Thread starterDoughy2002
Doughy2002
OP-COM.v1.39.For.Opel
I got this copy of OP-COM. If something is good, it is old.
OP-COM v1.39 supports various diagnostic and programming functions for Opel/Vauxhall vehicles. Some of the main functions are:
  • Real-time data display. You can view real-time data from various sensors and actuators of the vehicle, such as engine speed, coolant temperature, throttle position, fuel pressure, brake pedal position, etc.
  • Read and clear fault codes. You can scan your car for fault codes stored in control units such as engine, transmission, ABS/ESP, airbag, instrument cluster, radio, display, etc. You can also clear the codes after troubleshooting, etc.
  • Perform output tests. You can activate and test various components of the car, such as injectors, coils, fans, relays, lamps, horns, etc.
  • Changing the variant coding. You can change various settings and options in the vehicle control units, such as language, units, alarm, central locking, etc.
  • Immobilizer support. You can program new keys or remote fobs for the car immobilizer system. You can also change the immobilizer code or disable it, etc.
  • It also supports other functions such as firmware update, CAN bus analysis, ECU reset, etc. However, some functions may not work with certain models or control units due to compatibility issues, etc.
  • new-op-com-139-software.rar
Reactions:peti96, Fotom, chris966 and 3 others
  • Christi325
difisi
ucmb
  • ucmb
ucmb
ucmb
blueabyss
  • blueabyss
blueabyss
blueabyss
