Open AMG Menu in my W205 car
  • Thread starterJeeg1975
Jeeg1975
Who can help me to activate the AMG menu on my W205? (IC222)
Start Stop Last Mode I made it. (with Vediamo)
Ty
Reactions:omsitbin
it is easy by using MBLink
Yes, but it cost €76, I would like to make it myself for €0
Reactions:Galahead
Good luck then :) You will pay more by spending time.
Probably, but I don't necessarily want it, it's more the desire to do it myself.
Maybe I'll remove it later again.
As with the seat belt warning, it was first deactivated and later activated again.
Hello,
I was looking for seed key generators to unlock the AMG menu and create the initial state for W212 and I didn't find any free options. MBTools, SKCtool. However, I found information on how to activate the AMG menu for free by modifying the counter's EEPROM memory. The method is more difficult because you have to disassemble the counter to get to the memory. But for free. All you need is a programmer.Regards
Reactions:Jeeg1975
Hello Spektra, for W212 you can buy a fvdi clone and use it with monochrome dashboard.
For the colour dashboard you need to flash a specific software with vediamo for using it with fvdi
Thats the cheapest way or you can desolder the eeprom and read it with a lot of reader.
Best greets
Nacka
Reactions:spektra
Best greets
Nacka
Hello, you are right, this is also the way. The advantage of this solution is that you do not interfere and do not disassemble the meter. Only cost more for one time use. Good, for someone who runs a workshop and earns money by activating this variant.I started playing with the CAN bus in the W212 and have a few drivers on the table. Including counter. The counter says unpaired, so I want to bring it back to its initial state. Vediamo is out of the question because you need a seed key generator. Personally, I derived the eeprom signals from the meter and I can modify it, regardless of the fact that I will break something. I can always program the eeprom with the original input and continue experimenting.Regards.
normaly it works with Vediamo, but nobody says how.
Reactions:juanjober
Yes it works with Vediamo but you need a Seed Key Calculator.
The Algo is not free, thats the problem.
  • waxxx
waxxx
  • MARCOSOFT
carman777
  • isookgoed
Bruto
Bruto
