Problems Flashing with Vediamo 4.02
  •  Vediamo
  • Thread startercbraeburn
cbraeburn
cbraeburn
Has anyone tried flashing SW or CFF with Vediamo+openport2.0 successfully?
I'm trying to flashing newer SW to HU45 with Vediamo v04.02 + openport2.0.
After clicking "Flashing Administrator, I then click "ADD, then tried to change folder to locate the cff file. but the locate file screen is blank and won't change and I can't navigate to any other folder. There is no other problems when changing coding, only issue is when doing flashing cff.
Vediamo 4 does not work with SMR F. That's why she doesn't see what you want to slip her. But there is no СFF on НU45.
Hi cbraeburn,
I have used Vediamo 4 + Openport 2 to successfully flash CFF files on a Smart 451.
The Flash Administrator can be a bit of pain, you can edit the Flashfiles.cfg by hand if you want/need.
Regards.
That is not correct CFF files do exist for HU45.
  • nemiro
nemiro
  • V3lmu
V3lmu
Bigovic
