Right CrashSensor for Airbag Ecu 4B0959655C
  • Thread starterDiagnos11
Diagnos11
Hello,
In need help to find right CrashSensor for the Airbag ECU 4B0959655C!
My bought Car: Audi A6 C5 1.8T 1998
There are CrashSensor G179 and G180 with number 4B0959643B, and the error is Open Circuit
I think the Crashsensors are not from this car!
When i replace with the same number, the diagnostic stay the same, but when i change to another number like 4B0959643C, then i have error Short to Plus!
Please help me with the right CrashSensor number for this Airbag ECU.
Thanks & Regards
Hi mate,
It sounds like you're dealing with compatibility issues between the crash sensors and the airbag electronic control unit (ECU) in your Audi A6 C5. It's important to ensure that the crash sensors you're using are compatible with your specific vehicle and ECU.
The part numbers you provided, 4B0959643B and 4B0959643C, likely correspond to different revisions or versions of the crash sensors. It's possible that the crash sensors you're trying to use are not fully compatible with your vehicle's ECU, resulting in errors such as open circuits or short circuits.
Reactions:Diagnos11
First of all, a vehicle identification tag is required to identify vehicle equipment. If you share that label, I can give you vehicle equipment and part number information.
Reactions:Diagnos11
Thanks to all, who has tried to help me.
The problem is solved, the compatible airbag crash sensor was 4B0959643A!
The thread can be closed!
Reactions:Wizzlo87
  • shadi
shadi
  • Ramikadze
rezk1y
  • nabs84
nabs84
