mattula
- 1
I just want to report a successful "repair" of the key.
I have had the S205 since November 2015 but it is now a 2016 model. It is not a keyless entry system, it is similar to the classic two button keys and is used to turn the ignition on by inserting it into the ignition and turning it.
According to my data, this key is FBS4, which no one but MB can fix. And MB does not fix it, they sell you a new key for a donation of about $600 or more.
So the symptoms were as follows:
The key did not open the doors except 1 in 100 attempts.
The key mostly locked the doors.
The key could always start the engine.
But the red control LED and IR light (seen by the smartphone camera) always blinked when I pressed the buttons, and they looked exactly like my working key, so I thought the problem was not with the button itself.
And no, it wasn't the battery, and even training the key by inserting it into the ignition and waiting for an hour or so didn't help.
So I opened the key case and pulled out the PCB. At first glance it looked fine, but maybe some of the solder points looked a little dull.
Therefore, I re-soldered all the contacts, especially from the buttons, and additionally heated the entire board with a heat gun.
And all this together can become a solution.
I approach the car... one press, the doors open, one press, the doors close even from a distance of 10 meters. It worked many times. Yes.
