Scanmatik SM2Pro Clone with Vediamo
  •  Vediamo
  • Thread starternemiro
nemiro
I've been trying for a long time to get this Scanmatik SM2Pro clone to work. Windows sees it, but I can't get Vediamo 4 to see it at all (part J). Tactrix works great, but switching to SM2Pro does nothing. I used the switch and manually edited the "slave.ini" files. Is there another driver or some procedure to make SM2Pro work? I tried both with and without the dongle.
  • N
    Given by nemiro
The solution to this problem was to use the registry file located here:
In addition to the steps you posted above. Thank you!
Try this first.
Modify your "slave.ini" as follows.
Code:
; PartJ configuration
PassThruVersion="04.04; should be "02.02" or "04.04"
DeviceName="Scanmatik - SM2 USB; only usable for 04.04 e.g. "Drew Technologies Inc. - CarDAQ" or "I+ME ACTIA - PassThru+ XS"
;FunctionLibraryRegistryKeyName="FunctionLibrary; only usable for 04.04
Please let me know if everything went well.
Reactions:nemiro
I now have SM2Pro running in Xentry/DAS, but it is still not available in Vediamo.
Reactions:Fotom
  • Reniu12
Reniu12
  • albert
kacpix500
kacpix500
V3lmu
  • V3lmu
Lapinpoikaa
