W203 is a simple DAS car, you can flash it in DAS, of course, you will need cr@ck for offline programming first, then you will need SDFlash files, you can find them in the forum. I recommend using an old version, the best is "Golden Version", and you can flash your car, of course, you will need a good battery charger. Also in Vediamo, I worked with this program for a long time, you will have difficulties. By the way, all variant codings will be lost, so you can make a new coding after flashing.
