Moderator
Staff member
Developer
- Solutions
- 17
- 5,393
STAR DIAGNOSIS Activation
Archive includes:
Activation process on the example of STAR DIAGNOSIS v11.2012, other versions have the same process.
First of all, you need to close StarShell.
If you do not want to see it in the future, rename (C:\WINDOWS\zak\StarShell\StarShell.exe to StarShell.bak) it.
Launch "STAR Utilities" from your desktop and copy the HW ID and LAN ID to a text file.
All these fields must be filled in with the generated activation keys.
Generate activation keys with HWID and LAN ID from the saved text file.
XENTRY.Developer.Opened.Keygen.v1.1.0, BHLM.Keygen.
You should have the same result as at the screenshot above.
If you want to activate the EPC, run Start > EWA > EWA (User: admin, Password: 12345).
Run Administration > Server > Edit the access authorization as above and copy "Current MAC address (LAN-ID)".
In EPC.Keygen click "Analyze Key" and enter the name of the included text file (v8dx3sqdf8pvefy7dwpvhg4ck2hezua.txt).
Then enter the copied EPC "Current MAC address (LAN-ID)" and click "Get Key".
The result should be the same as above.
You do not need to use EWAnet WIS/ASRA activation key, we have WIS/ASRA in standalone mode and the "EWA net DB WIS" service was disabled in the system by me.
If you want to run EPC from a shortcut instead of from the EWAnet interface, you must first remove the old EPC shortcut from your desktop.
After that remove it from Java Cache Viewer as shown in the picture above and do not close these windows.
Launch EPC.
You will have a new EPC shortcut in the Java Cache Viewer. Press "Install Shortcuts". After that, a new EPC shortcut will be created on the desktop under the current user "STAR".
If you want to see it in StarShell, move it here (C:\Documents and Settings\All Users\Desktop).
OS: MS Windows XP
Installed size: 4 MB
Archive includes:
- BHLM.Keygen
- EPC.Keygen
- MS.Windows.XP.Activator
- XENTRY.Developer.Opened.Keygen.v1.1.0
Launch EPC.
OS: MS Windows XP
