The title says W168, the topic text says W169. W168 is only coded with HHT. W169 can be coded with both Vediamo and DAS engineering. What car are you asking about? W169 is coded without problems.
I changed the coding in the IC via DAS engineering (set Limiter - Vorhanden) and in the SIM266 engine via Vediamo (set Tempomat\Limiter - VGB and Tempomat ON).
