blankebob
- 1
I will share an interesting thing that happened to me when I was working on a Renault Clio.
Clio constantly goes into limp mode, engine stalls, different lights on the dashboard, etc.
When I read the data from the car, it gave an error about the throttle valve, replaced it with another throttle valve, but still no result.
After a week, I found the problem, the brake light sensor on the pedal was faulty, just replaced it and everything worked again.
Just so you know, if you can't find the problem in the Clio, it could be the switch.
