Vediamo Engineering Mode W213
  • Thread starterUser
User
Member
I have a W213 and I want to activate the engineering mode via Vediamo. I have the database but no HU55. Does anyone know where I can get it or share it?
Explain what exactly you need. Engineering mode for HU can be enabled by a key combination on HU, such as headphones + # + 1, etc.
I want to enable mirroring feature and change region from US to EU and some other settings on the go.
First check what head unit you have. If you have Xentry, try checking with a basic test which ECUs will be recognized. I haven't made any changes to any of the new HU6s, but it may turn out that the changes described are not possible at all. But first check what your HU is.
I have NTG 5.5 and no Xentry, but I have Vediamo and DTS Monaco.
HU55 COMAND region is based on serial, need to change serial to change region, mirror link can be enabled by coding.
Can you tell us more about the serial?
For this you will need the SMR-D file, this is a new unit.
The easiest way is to search for the new DTS Monaco project database. One of them is provided by the administrator R00TR0w.
SMR-D can be used by DTS Monaco.
Is it possible to change serial on DTS Monaco using SMR-D files?
  • Selectronic
cmkfarooque
  • User
AstronBnX
  • artur666
ELMACHT
