W166 GL Reverse Camera Not Working
  • Thread starterabrish27
abrish27
Help please, rear view camera W166 GL does not work, malfunction in the head unit control unit, error code C264 "Communication with backup camera has a malfunction".
It is written there clearly as day and night that the signal from the corresponding module does not reach the camera, first check the wiring from the camera to the module to which it goes, if this does not help, check the camera.
Reactions:PaskaYbivaska and abrish27
Were you able to solve the problem?
Your COMAND system may need an update. Try installing the latest navigation discs, which also contain updates for the head unit. This seems to have fixed many people's camera problems.
Reactions:abrish27
Problem solved. Thanks everyone.
Reactions:xsesiv, PaskaYbivaska and X164
How did you resolve the issue?
By programming the COMAND head unit.
  • IlanISR
IlanISR
  • BMGarage
Z
  • ZiMMeN
krugger
