W166 ML350 AdBlue Abolition and EGR Abolition
  • Thread starterBIBSHIGE
BIBSHIGE
What do I need to eliminate AdBlue and EGR?
I have XENTRY, DTS Monaco v8.16, Vediamo.
Can I change it via OBD?
Can you read and post file from engine ECU?
I don't know how to access the ECU files. Can I do this via DTS Monaco or Vediamo?
DTS Monaco can only reset the value, but first you need to know the ECU type.
To remove it completely you only need to modify the file.
Do I need to remove the ECU from the car?
You can use XENTRY and then see which ECU version it matches.
Reactions:BIBSHIGE
PСMFlash, аlternatively, read the calibration and replace it with a calibrated file, with AddBlue and EGR disabled. Xentry, DTS Monaco, Vediamo are not suitable for this procedure.
Reactions:BIBSHIGE
Read the file and I'll modify it for you.
Where can I get the modified files? What software do I need to burn them?
If you don’t understand what I’m talking about, then it’s cheaper and easier to go to the station where they do it.
If you only want to make your own car, it will be very expensive. you will have to buy hardware and software.
Reactions:BIBSHIGE
  • CarTuning
  • alfaohc
alfaohc
  • Ossion
P7uggy
