Alinut
- 6
I had a problem with the Multibeam headlights on my W177, the low beams would randomly turn on when parking. In all cases, only one headlight was turned on. The problem usually went away on its own since I couldn't do anything to turn off the headlight. I changed the ECU for both headlights at MB workshop, but the problem remains. Also after replacing the ECU, the LEDs are not aligned, and the light pattern for both low and high beam looks bad, with noticeable dark spots.
