S skarpeon555 New member Joined 28.08.2023 Messages 5 Reaction score 11 20.04.2024 #1 Synchronization of used KI with EZS for W204 with Vediamo. Download attachments W204 Sync used KI to EZS with Vediamo.jpg 128.3 KB · Views: 220
H hafsa Junior member Joined 10.03.2024 Messages 52 Solutions 1 Reaction score 18 21.04.2024 #2 Thanks for this information, but it will be better if you describe all the steps. Synchro KI with EZS is usually based on SSID.
M Mersovod Junior member Joined 16.04.2024 Messages 95 Reaction score 48 21.04.2024 #3 Synchronization is not a problem. Only the KI should be like new. And this is a completely different process.
S skarpeon555 New member Joined 28.08.2023 Messages 5 Reaction score 11 22.04.2024 #4 Synchronization with the ignition switch is only possible with a mileage of up to 250 km.
M Mersovod Junior member Joined 16.04.2024 Messages 95 Reaction score 48 23.04.2024 #5 It's clear. Show how to set zero mileage for the instrument cluster you are using.
H hafsa Junior member Joined 10.03.2024 Messages 52 Solutions 1 Reaction score 18 26.04.2024 #6 Mersovod said: It's clear. Show how to set zero mileage for the instrument cluster you are using. Click to expand... But EZS and KI must have the same SSID. Even if you set KI to zero km and do not change the SSID, rest assured the km will not be displayed.
S skarpeon555 New member Joined 28.08.2023 Messages 5 Reaction score 11 27.04.2024 #7 You can use Vediamo, but you will need a Seed Key. PROTOCOL = UDS 1. Unlock 09 = 27 09 2. Unlock 0D = 27 0D 3. Write Mileage = 3D 14 00 00 00 64 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Reset IC = 11 01
