W211 Add CD Changer Coding
  • Thread starterV3lmu
V3lmu
The car owner wants the car radio to have Bluetooth functionality. Received instructions from the accessory manufacturer on coding the CD changer for the radio.
Is coding successful with DAS program? How is this coding done?
Car: 2006 MERCEDES-BENZ E 280 CDI 4MATIC 211.284
I found these points using the DAS program, but despite all my attempts, I could not get the CD changer to appear in the radio.
abc123
Code:
WDB2112841X219850
2006 MERCEDES-BENZ E 280 CDI 4MATIC (211.284)
General Data
FIN WDB2112841X219850
Model E 280 CDI 4MATIC
Engine 642921 40 292574
Transmission 722689 06 700771
Order Number 0 6 219 10248
Order Location HAMBURG BRANCH
Production Number 9816811
Interior FABRIC, ELEGANCE - BLACK / ANTHRACITE (441A)
Paint 1 TANZANITE BLUE METALLIC FINISH (359U)
Release Date 2006-10-20
Delivery Date 2006-12-07
Code Description
06N STEUERCODE WERK SINDELFINGEN/GRAZ
10N STEUERCODE WERK SINDELFINGEN/GRAZ
110 FUEL AMOUNT FOR COLLECTION BY CUSTOMER
202B OWNERS MANUAL AND SERVICE RECORD - GERMAN
213 SPEED-SENSITIVE POWER STEERING/VARIO STEERING
220 PARKTRONIC SYSTEM (PTS)
229L GERMANY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
250B MOBILO LIFE/EUROPE SERVICE PACKAGE
260 TYPE DESTINATION ON TRUNK LID - ELIMINATION
260B AIRBAGLABEL - GERMAN/ENGLISH
287 THROUGH-LOADING FEATURE
289 WOOD/LEATHER STEERING-WHEEL
2XXL FEDERAL REPUBLIC OF GERMANY
309 CUP HOLDER
354 ANTENNA FOR TELEPHONE D/E-NET
359U TANZANITE BLUE METALLIC FINISH
386 MOBILE PRE.-INSTALLATION (MTUS)
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
423 5-SPEED AUTOMATIC TRANSMISSION
440A FABRIC, ELEGANCE
441A FABRIC, ELEGANCE - BLACK / ANTHRACITE
474 PARTICLE FILTER
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
527 COMAND DVD APS WITH NAVIGATION
550 TRAILER COUPLING
580 AIR CONDITIONER
673 HIGH-CAPACITY BATTERY
731 WOOD TRIM BURRED WALNUT ROOT
807 AEJ 06/1/M/X
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
910 DYNAMO WITH HIGHER CAPACITY (FFO)
915 FUEL TANK WITH LARGER CAPACITY
926 EXHAUST GAS CLEANING WITH EURO 4 TECHNOLOGY
955 EQUIPMENT PACKAGE ELEGANCE
985 COC PAPER EURO 4 TECHNOLOGY W. REG. CERT. PART II
K11 ADAPTIVE STOP LIGHT FLASHING
M002 ENGINES WITH EXH.TURBOCHARGER WITH INTERCOOLER
M005 VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M013 ENGINE REDUCED PERFORMANCE
M30 DISPLACEMENT 3.0 LITER
M642 V6 DIESEL ENGINE OM642
N23 STEUERCODE WERK SINDELFINGEN/GRAZ
N28 EXCHANGE NOT ALLOWED, BODY/ORDER AS OF OFL W/ PA1
P78 FLEET MODEL
P80 SPECIAL MODEL FLEET PACKAGE
R01 SUMMER TIRES
R76 LA 16" 11 SPOKE DESIGN
U15 2ND CARGO AREA W/ COMPART. UNDER MAIN FLOOR PANEL
U16 STOWAGE TANK BEHIND REAR SEAT BACKREST
V06 SPEED- + LOADINDEX 95W
Are you trying to add a CD changer to your audio system?
If so, you have to code the most ring with the proper vehicle configuration. Look at the third and fourth pictures and notice that position 2 has changed: the CD changer has been removed and the navigation has been moved to position 2.
Yes, this coding is done in the Audio Gateway (AGW) using DAS and should be under the "adaptations" tab in AGW.
Yes, the Bluetooth device connected to the player must be "CDC". The manufacturer's website states that in order to use a Bluetooth device, the player must be encoded with "CDC".
You would need to connect Xentry, read out your current Most ring configuration, and then add CDC in the correct spot in the Most Ring.
