W212 DPF differential pressure sensor
  • Thread starterBiohazard_SVK
Biohazard_SVK
Biohazard_SVK
Hi all. Error B28/8 appeared on W212 year 2011. The car goes into emergency mode. No other error was diagnosed. Do you recommend replacing it with an original part or is it also possible to use a BOSCH or DELPHI sensor?
Hello to you, if this can help you, I have already replaced with compatible ones and from the origin it is exactly the same, you just have to go to the suitcase to reset them.
Thank you for your response. I put BOSCH and reset the errors. I did a DPF test then did a DPF regeneration and the car's performance issues went away.
Had the same problem. Bosch sensor will last you about a year. Only replace with original Mercedes-Benz, will last for years.
Mercedes doesn't manufacture them by themselves. For W212 they are bought from Bosch. The only difference between Bosch and Mercedes is that Mercedes parts have both numbers Bosch and Mercedes as well, while Bosch parts have only the Bosch number.
  • ber5ien
ber5ien
  • satmonster321
waxxx
