W222 Add an Additional Language to the COMAND Screen
  • Thread starterDubai80
Dubai80
W222 2018, couldn't find anything related to adding language to COMAND via DTS Monaco. Any suggestions?
Reactions:mattehardware
It's a simple job! You need to edit it in HU5 -> 011 Several applications write. If you don't have it, you have the wrong project.
You are right, but this is for W222 2015-2017 S550.
I have a 2018 S560 and the HU5 is not working. It is a HU55 and there are several apps but I don't see anything related to the COMAND language list.
Where is this car from? USA ECE or something else?
Exported from USA to Dubai.
Ok, try doing it with DTS -> 17.VCD_Radio_Range_Types and set this.
Code:
Fragmente: Werte
Range type AM/FM: ECE (USA in your case)
Range type LW: off
Range type SW: on
And after a Hard Reset, try changing the language and let us know.
Reactions:OMNI2828
I have long ago changed the settings to adjust the frequency of my country, but Arabic is still missing from the menu.
The region in COMAND is based on the serial number. To have more languages, you need to change the serial number or install a software patch.
In Dubai you can use this service.
Code:
Fragmente: Werte
Range type LW: off
Range type SW: on
And after a hard reset, try changing the language and let us know.
Yes, I did that, but nothing changed. What else can I do?
Unfortunately, if you can't change the situation with these parameters, you need to go to change the COMAND serial number, which is a service offered by third parties. There are not many options to do it yourself... Above you were given a link to one of your local services, otherwise, if you have an ENET cable, you can try to search remotely for a better offer.
  • Dubai80
yunushaidari
  • yunushaidari
  • Marketplace
