W222 from US to EU
  • Thread starterpercooo
percooo
percooo
I have done a conversion from US to EU W222. The road sign assistant does not work and I have no connection with the head unit. Is it possible to fix this with an EU maps update?
No, you need to change the serial number to HU, reflash, code and after that everything will work fine.
As far as I remember, this can be done using MBTools.
No, this is not possible with MBTools.
Reactions:B0bby92
You can use MBTools to purchase the code. Download the maps using the map download tool on this forum. Create a USB stick and install the maps using the USB and the code from MBTools.
Reactions:trigital
What do you mean when you say you have no connection with the head unit?
The road sign should be fine, no conversion is required to load EU maps.
  • briani_204
  • Software requests
  • Kevina45
EdoM
EdoM
